8550 3 pt. lift
davids
10-30-2006 16:44:42
the 3 pt. lift wont lift and the remotes are dead as well. changed filters and they needed it. checked the hyd. pressure at the pto valve and only had 180#. the pump had been making noise like it was cavitating but now no noise at all. before it would lift the remotes but was VERY SLOW and only would lift at an idle.Now nothing. No pressure at all at the remotes. Any help is appreicated. Thanks, davids
856 puller
11-03-2006 04:46:23
 Re: 8550 3 pt. lift in reply to davids, 10-30-2006 16:44:42
if the filters were plugged with metal you need to find out where it was comming from. i think there is a pickup screen on the bottom of the pump you should look at it make sure your filters are in right. there is a screen in the end of one filter make sure it is in.
