AC loader hydraulic cylinders
Phjay
10-29-2006 17:05:25
I am new to this site and realize it is supposed to be about tractors. However, I am having the devil of a time trying to find replacement cylinders for my AC loader and someone out there might be able to help. The loader is mounted on a AC 175 deisel rowcrop tractor. The loader is type # 571137, serial # 00376?? (last digit is corroded.). I need the cylinder that connects to the bucket. It has about a 1" shaft, 2" bore, and 19.5" stroke. Any help is much appreciated.
klf
10-29-2006 17:56:03
 Re: AC loader hydraulic cylinders in reply to Phjay, 10-29-2006 17:05:25
If it is an Allis loader like we have on our 175, the seal kits are available from AGCO (last I knew). What is the matter with your cylinnders?
P.S. If it has anything to do with a tractor like the loader, there shouldn't be any problem posting your questions.
Phjay
11-01-2006 17:09:10
 Re: AC loader hydraulic cylinders in reply to klf, 10-29-2006 17:56:03
thanks for your comment. One of the cylinders has a badly bent shaft and need to be replaced. The other was taken apart without my permission by a hydraulic shop that will not put it back together without charging for it.
At present I have two lighter duty cylinders "off the shelf" at tractor supply. Ideally I would like to repalce the same heavy duty cylinder I had.
