B Value?
Caleb Fox
10-29-2006 15:50:29
Found a 1940 B. Runs good, but has crack in block. Motor does smoke some. Has 3 point and rear grader blade. Just wondering what kinda price it would be worth.
steve(ill)
10-29-2006 18:10:57
 Re: B Value? in reply to Caleb Fox, 10-29-2006 15:50:29
i have bought plenty of small B and C tractors that run for $700-750. A cracked block will cut that price, but the 3 point and blade add a little. $600-700 would be a good price. If you need a block, that will add cost. If you plan on jb weld, that might get you by, but the smoke means it needs overhauled.
old
10-29-2006 16:08:30
Depending on how bad the crack is and if it leaks or not. Also depends on the tires and sheet metal. One like that to me might be worth $700-900 because of the cracked block. Now one in good shape with good tires can bring up to $1500-3000 if all is good to very good
