6 volt batt.
vjd
10-26-2006 19:29:29
I have a 6 volt batt in a model A car neg ground I want to use this same batt. in my wd45 AC it is a gen. that is pos ground can I put it in the tractor? or can I change the tractor gen. so it will charge with the batt. in the neg ground?
RustyFarmall
10-27-2006 13:24:00
 Re: 6 volt batt. in reply to vjd , 10-26-2006 19:29:29
Model A Fords were originally positve ground.
jvd/s.d.
10-27-2006 17:35:40
 Re: 6 volt batt. in reply to RustyFarmall, 10-27-2006 13:24:00
Rusty--- You are right Model A ford is pos ground my fault
old
10-26-2006 20:08:13
Batterys don't care if you hook them up + ground or - ground but some tractors do. So yes you can use that battery on a + ground tractor with no problems
