WD-45 belt pulley
Kevin Blake
10-24-2006 17:51:13
In the process of purchasing a WD-45 with a belt pulley. The WD-45 dad had when I was a little kid he used the belt pulley to power a sheller, but we got a combine and I never did learn how to engage the pulley. I don't know how to engage the pulley, and neither does the seller. Can't find a lever. Does it have to be in gear to run? Anyone know how to do it?
Eldon (WA)
10-25-2006 08:08:38
 Re: WD-45 belt pulley in reply to Kevin Blake, 10-24-2006 17:51:13
There is a series of holes (dimples actually) in a spiral around the barrell of the pulley. You have to pick the right one for the proper backlash. If the pulley is original to the tractor, there should be an index mark stamped on the barrell and the frame rail of the tractor that would line up for proper backlash. If not, obtain the proper backlash and then mark it for future reference.
Tramway Guy
10-25-2006 05:50:39
There is a setscrew with a locknut on it that keeps the pulley disengaged (or engaged, as the case may be). To make the pulley run, back out the setscrew; then push the pulley assembly into the housing, it will engage with a gear on the clutch shaft (did I mention that the engine has to be shut off for this?).
Retighten the setscrew, it is supposed to engage with a hole on the pulley assembly, and end up with the correct 'backlash' of about 1/8" or so. If the backlash is not correct, let us know. The only way to stop the pulley running with the foot clutch out is to reverse the whole procedure. The difference is that instead of a hole, the setcrew sits in a groove when the pulley is disengaged.
Will Herring
10-24-2006 19:57:52
I seem to recall grandpa telling me you had to clutch the tractor a special way and it would start up... But I don't remember how. I'll ask him next time I see him, if I remember.
old
10-24-2006 18:29:46
To engage it you pull the lock screw out and then slip it in some more. Then it will run any time the clutch pedal is out. After you have it set in you just put the lock screw back in. Theres a way to adjust it to have it right but I don't remember all of that part of doing it
