wc manifold studs
slowride II
10-22-2006 17:47:51
where can I get em? couldn't find any on ebay, and none in the parts department here. anyone know? if it matters, i have the early type manifold without vertical exhaust. T.I.A
slowride>
Steve in NJ
10-24-2006 03:49:57
 Re: wc manifold studs in reply to slowride II, 10-22-2006 17:47:51
Tony's Tractors has stud kits in stock for the WC, WD,WD45. They have a website.
Steve@B&B
Will Herring
10-23-2006 18:35:17
I was able to order a set for my WD... But unsure about a WC.
JMS/MN
10-23-2006 23:26:53
 Re: wc manifold studs in reply to Will Herring, 10-23-2006 18:35:17
Same block, manifold, same bolts. Available from AGCO. Dealer locator is at www.agcocorp.com.
wdTom
10-23-2006 17:52:58
Made mine out of stainless steel. Threaded on the lathe. Got a friend with a lathe?
slowride II
10-23-2006 19:26:21
 Re: wc manifold studs in reply to wdTom, 10-23-2006 17:52:58
can"t i just use grade 8 thread all? i"m not looking for originality. this is for a working/pulling tractor and all i need is something to hold the manifold on. thanks for the responses.
slowride>
CAL(KS)
10-23-2006 04:30:02
your local NAPA should have them they carry many types of studs. Last I checked they could get up to 1/2 studs, 5 in long. THey should have some smaller to fit wc.
37WC
10-22-2006 19:08:47
I was desperate and went to my local IHCASE dealer and showed the parts man my old stud. He went back in his inventory and brought out the simliar one for an M-Farmall. They were a little long, but a grind stone solved that problem. Good luck.
37WC
TobyWellborn
10-22-2006 17:56:05
Here is where I got mine...
They are a AGCO Dealer
Sandy Lake Implement
Rt. 173N--3675 Sandy Lake Rd.
Sandy Lake , PA
16145-9803
e-mail:
[email protected]
Phone: (724) 376-2489
