WD45 Specs.
tractornutjd
10-22-2006 10:31:23
Hello, could someone give me the connecting rod bolt specs for a wd45 gas tractor. Also, why would the rear half crankshaft lose oil? Thanks in advance.
CTuckerNWIL
10-23-2006 18:30:41
 Re: WD45 Specs. in reply to tractornutjd, 10-22-2006 10:31:23
You can plug the back end of the cranshaft instead of using an oil wick ,put in an oil-filled pilot bushing.
Dale Arnold
10-22-2006 13:15:39
Hi,your connecting rod bolts need to be tightened to 70 Ft. Lbs. if you are using castellated nuts if you are using lock nuts they need to be tightened to 40 Ft. Lbs.,as to your crankshaft losing oil out of the rear you might need to change the oil wick in the flywheel end of the crankshaft. The piston pin clamp screw needs to be torqued to 20 Ft. Lbs.
Good luck with your tractor.
