Wiring Diagram Needed
Shaun Murray
10-21-2006 10:23:58
I am in need of a wiring diagram for a 2 plug alternator for a D-14. I am converting it to a positive ground alternator system and would like to have a wiring diagram before I burn everything up. I would appreciate anyone's help in locating one of these. My email address is [email protected] should you be able to send it directly to me.
Thanks in advance,
Shaun Murray
steve(ill)
10-21-2006 14:44:39
 Re: Wiring Diagram Needed in reply to Shaun Murray, 10-21-2006 10:23:58
the best advice i can give you is to throw the positive groudn alternator in the nearest dumpster and get a DELCO or smaller japaneese unit and install. any alternator with internal voltage regulator will work good.
Bob
10-21-2006 12:08:49
I'm NOT familiar with the electrical system on a D-14, but I repair alternators for a living, and can probably get you a generic diagram, if no one else posts a redy-made one, but I need a little more information.
So, you have purchased a special POSITIVE ground alternator, correct?
What is the make and model of the alternator?
