Trans. Diff Fluid?
SEK Bob
10-20-2006 11:28:20
Does the WD45 use 90 weight Transmission and Differential fluid? Thanks for all the help. I need it.
steve(ill)
10-21-2006 14:52:48
 Re: Trans. Diff Fluid? in reply to SEK Bob, 10-20-2006 11:28:20
i think original fill ws 17 quarts of 90 wt gear lube for the transmission/ bevel gear. the hydraulic cavity takes thinner 10 or 20 wt. There is a new universal trans/ hydraulic fluid that some have use in the transmision, but it is based on a 20 wt oil and some people think it is too thin. You basically use the same system as the D17.
