Sediment bulb bail
SEK Bob
10-19-2006 07:06:46
Does anyone know where I could order a sediment bulb bail assembly with screw & nut for a WD 45. I just want the bail and screw. Thanks
Butch(OH)
10-19-2006 15:49:41
 Check the new bowl before you install it in reply to SEK Bob, 10-19-2006 07:06:46
Just a warning about the new bowls they sell at TSC. The last three I bought were not machined correctly where the needle seats in the main body. Discovered the first one would not shut off after I had screwed it in the tank and tank was full of full. I looked after that. A quick trip the the Bridgeport with a 5/16 center cutting mill fixes them but not many have a mill in the shop.
John (MO)
10-19-2006 13:18:22
 Re: Sediment bulb bail in reply to SEK Bob, 10-19-2006 07:06:46
Every body has at least 3 of them mixed in will all the other junk they own. If they would have just labeled them as to what they fit before they carefully put them away it wouldn`t be no problem at all. However, under current conditions it might take most of a week to dig one up.
old
10-19-2006 07:48:04
For what the parts will cost you, you would probably be better off just buys a complete sediment bowl assembly. Ne they are only about $15-20 and just that part will probably cost very close to that if not more
RustyFarmall
10-19-2006 11:48:56
 Re: Sediment bulb bail in reply to old, 10-19-2006 07:48:04
Old, once again we are in agreement. The entire sediment bowl assembly, like you said, will cost somewhere around $20. I just see no point in messing with the old one.
Dick L
10-19-2006 11:56:34
 Ya in reply to RustyFarmall, 10-19-2006 11:48:56
Cause you rich guys have 20 bucks. (:^D
old
10-19-2006 12:01:41
 Re: Ya in reply to Dick L, 10-19-2006 11:56:34
Nope I don't have the 20 bucks but if your going to buy just the bale for it that will cost very close to what it cost to buy the whole sediment bowl assembly so why not spend 2 or 3 more and have the old one for parts
RustyFarmall
10-19-2006 13:00:38
 Re: Ya in reply to old, 10-19-2006 12:01:41
All ya gotta do is sell me that '51 M and then you would have 20 bucks. 'Course you'd hafta lend me the gas money to come get it.
old
10-19-2006 13:45:42
 Re: Ya in reply to RustyFarmall, 10-19-2006 13:00:38
Shoot right now you wouldn't want it. The water pump is locked up so tight that its almost going to take a stick of TNT to brake it loose. Other then that it purrs like a kitten
Dick L
10-19-2006 12:04:04
 Dang It Old in reply to old, 10-19-2006 12:01:41
I was picking on the two of you.
old
10-19-2006 12:50:44
 Re: Dang It Old in reply to Dick L, 10-19-2006 12:04:04
LOL, so I was just picking back and also stateing a fact LOL
gene (missouri)
10-19-2006 07:16:18
Nearest tractor dealer. Most carry an assortment of sediment bowl parts.
