WD Wide Front End
Persian Paul
10-16-2006 13:17:55
I have to replace the tie rods on my WD. What is the best way to align the front end so I don"t drift all over the road?
Texas Denny
10-16-2006 13:29:07
 Re: WD Wide Front End in reply to Persian Paul, 10-16-2006 13:17:55
I use a tape measure. The only adjustment that you have is toe-in. Hook a tape measure on the outside of the center rib (or inside rib if you only have two rib tires), half way up on front of tire and measure the distance to the same point on the other tire. Then perform the same measurement on the back of the tire. These measurements should be the same. If you are doing a lot of high speed road work, you should have the front measurement be abour an 1/8" smaller than the back measurement.
