allis chalmers b
johnnydee
10-15-2006 08:51:32
im interested in a making this tractor a 12 volt system and starter,but ive looked at several other tractors within the same yr,1939-1940's and have noticed between the transmission and the rear end that theres a long housing that can be changed to modify the existing tractor of crank start to 12 volt starting...also looking on rims 10-24 for this tractor if any ? any manuals anyone would have,i have a loader with this tractor,i think it was a home made job but its wrks fine.and any other info you can give me on this model of tractor !!!!! !!!!! !!
steve(ill)
10-16-2006 18:38:38
 Re: allis chalmers b in reply to johnnydee, 10-15-2006 08:51:32
you need the torque tube with the starter hole, a flywheel with the ring gear on it, a battery ,a generator or alternator and some wiring. the battery box will need to be installed and possibly change the sheetmetal under the gas tank to fir the battery box. it might be cheaper to trade for a B that is a couple years newer with starter. it can be done, but might not be cheap and will be some work. does it have hand brakes also?
IBorange in TX
10-16-2006 11:20:03
I have some manuals, email me.
D13
10-16-2006 07:33:01
Make sure your tractor has 2 bosses on the left front engine block for the generator bracket (if it doesn't already have a generator). Some of the earliest don't seem to have this.
old
10-15-2006 12:29:30
Sounds like you have one of the ones that didn't have a starter on them. If thats true you need to find a torque tube made for the starter and also a starter, 6 volt or 12 volt start works well on 12 volts. I even have a couple of the torque tubes if you do need one. E-mail is open. Right now I have 4 Allis C which almost all part from a C will fit the B also. @ of the ones I have are parts tractors
Texas Denny
10-15-2006 11:56:51
The B can be cranked at 12 volts without any modification. The generator will need some attention to get it to charge at 12 volts.
