allis chalmers wc
johnny w
10-15-2006 08:00:09
my wc ran fine before i changed plug wires.now it runs fine until it smothers and finally dies like it might have water in the gas.i added a lead substitute to the gas before this started.i think it might be the magneto.
Steve in NJ
10-24-2006 04:20:28
 Re: allis chalmers wc in reply to johnny w, 10-15-2006 08:00:09
As the other fellows mentioned, if your tractor is mag fired, it needs to have solid core spark plug wires installed on it. You might have installed radio resistor wires which plays havoc with magneto's. We offer spark plug wire sets specifically made for certain model AC machines. Drop us a line if interested. Be glad to help ya out...
Steve@B&B
chalmersbob
10-15-2006 18:12:44
you need to have good soild copper plug wires. not the resistance auto type with these old tracrors. Bob
Sid
10-15-2006 13:38:17
"my wc ran fine before i changed plug wires.now it runs fine until it smothers and finally dies like it might have water in the gas." Check it out. That is easier than having the mag checked out. "i added a lead substitute to the gas before this started." Maybe you added water or something to the gas to the gas. "i think it might be the magneto." If you are positive it does not have water in gas, put old wires back on and see how it runs.
old
10-15-2006 12:25:57
You say new plug wire and also you say mag. Did you buy the right type plug wires for it?? If you got a set of plug wires made for a car or truck theres a big part of your problem. If it has a mag you need true wires core plug wires since mags don't work well on the auto type plug wires
Texas Denny
10-15-2006 11:54:47
Before doing other changes, get a good ohmmeter and measure the resistance of each of the plug wires. I've made up some of these wires and found the resistance of the wires at infinity - wide open. To solve, I stripped an 1/8" of insulation on both ends and soldered the connections. These pierce type plug wires can be problematic.
The lead substitute shouldn't be a problem if you mixed according to directions.
