Model G firing order question??????
Dave R S
10-14-2006 12:45:56
Can anyone tell me where no. 1 cyl. is located on the head and on the dist. I got the firing order from the manual but don't know where to start or which direction? Also can I use Kubota UDT hytran fluid in the trans? I can't find 20W gear oil
Don L C
10-21-2006 10:27:20
 Re: Model G firing order question?????? in reply to Dave R S, 10-14-2006 12:45:56
My manual says use 20w non-det. engine oil.....
maricopa
10-14-2006 19:21:31
Look for timing mark thru inspection hole, when engine is at tdc, look under cap to see where rotor is pointing. Mine is mag, so I can't tell you re:dist.
DAVE R S
10-14-2006 17:38:20
Yes, I know that. Sorry I must not be asking the question plainly enough.
Joe M(GA)
10-14-2006 13:11:54
Number one is on the Crank pulley end. You might find the UDT a bit thin, it may tend to leak when a thicker oil won't. If you don't have hydraulics, I'd use 90 wt gear oil, that's what is in both of mine.
DAVE R S
10-14-2006 16:09:40
 Re: Model G firing order question?????? in reply to Joe M(GA), 10-14-2006 13:11:54
From the rear of the tractor which is actualy the front of the motor 1342 back?
Joe M(GA)
10-14-2006 17:32:12
 Re: Model G firing order question?????? in reply to DAVE R S, 10-14-2006 16:09:40
Correct, the rear most part of the tractor is the front of the engine
