CA Allis Motor ????
Patches
10-11-2006 19:30:44
How big can you bore a CA Allis motor and still use the orginal sleeves even if you have to go to an automotive pistons? And if you have to go to automotive pistons, what size do you need?
Also, is there a web page that has the specs for a CA such as piston specs?
Thanks
Dick L
10-12-2006 13:27:23
 Re: CA Allis Motor ???? in reply to Patches, 10-11-2006 19:30:44
3 7/16" pistons would be as large as you could get factory sleeves and pistons. The sleeve is not all that thick with that diameter of a bore. If you bore out the block you can put in 3 1/2" pistons with the D-15 over bore sleeves. That is what I have in my C. You would have to spend some time in the parts books but if I remember correctly I had found a combo of parts that I could go to 3 9/16" but the block would have to be bored out larger than the what it takes to install the D 15 sleeves. If you bore any larger the sleeve tops overlap. At 3 1/2" you can still get by with the standard head gasket. Any larger and you would have to have a custom made copper gasket.
