43-WC engine siezed
DCT
10-11-2006 09:05:24
Just inherited my great uncle's 1943 WC.Lots of work to do but first,the engine is seized up. Going to pull the head and drop the oil pan to
have a look.Got a brain storm for loosening the pistons if every thing looks ok.I am thinking of making a spark plug adapter to pump grease into the cylinder head to loosen the piston's up one at a time.The run of the mill grease gun will put 3000 LBS per sq inch of pressure in a grease fitting.I realise that the valves will have to be closed to fill the cylinder head.Anybody think this would be a good way to loosen the pistons up?
D17JIM
10-11-2006 13:06:59
 Re: 43-WC engine siezed in reply to DCT, 10-11-2006 09:05:24
I used the grease gun method on a 44 MH many years ago and it worked well. I would put in tranny flid today and leave it and after several days try the grease as a last measure. Tranny fluid almost always works.
DCT
10-11-2006 09:54:52
Thanks. Will try tranny or brake fluid first.I will also need some sheet metal(fenders,hood)any resources for these parts?
old
10-11-2006 10:18:33
 Re: 43-WC engine siezed in reply to DCT, 10-11-2006 09:54:52
I have a pair of fenders laying around but they aren't the best in the world
Garry from SD
10-11-2006 10:05:16
For fenders and hood it depends on how much you're willing to spend. I've seen fenders from $150 to $200 a piece. I ended up buying a whole tractor on an auction for just the fenders. Paid $200 for the whole thing and the fenders were in the best shape I've seen.
It may take awhile to get good tin but it's well worth the wait.
old
10-11-2006 09:22:47
Your going about it the hard way. Stop where you are and fill the cylinders with tranny fluid and give it a week or 2. I just got in a tractor yesterday that was locked up and drove it today. What your thinking about doing will brake a lot of thing and end up costing you big bucks if any thing goes wrong. Out of 10 plus engines in tractors I have had that where locked up I have only had to pull the head and pan off one of them and thats my 1946 C which I use a lot
85_Ranger4x4
10-11-2006 09:15:14
Dunno about grease, we have used the hydraulics from another tractor, sometimes it works, sometimes it doesn't. You have to be carefull you don't break anything, we do it as a last ditch effort before we take the head off. Usually they come loose with a brake fluid soak thru the spark plug holes. Others use various concoctions of penetrating oil or tranny fluid, but the brake fluid works well for us and is pretty cheap.
