b with combine motor help
roland withersp
10-04-2006 17:18:33
was there such thing as a allis combine motor from a pull behind allis combine, and did they have more horsepower than a regular b allis
CA+
10-05-2006 20:13:58
 Re: b with combine motor help in reply to roland witherspoon, 10-04-2006 17:18:33
GET YOU A D14/D15 G149 OR G160 BIG HP IN LITTE ENGINE.
D13
10-05-2006 06:33:01
My B was repowered with one.
The stamp on the engine block (on flange at left rear) will begin with CR instead of CE (or BE for the early engine). The governer gives 200 more RPM (1600 vs 1400 if memory serves) which can be duplicated on a CE engine by adjusting the linkage. There is an oil management tray mounted over the valves (apparently the combines had a tendency to suck oil down the valve stems). Other than that I can see no differences to my other B's with the CE enigines.
Jerry Coulter
10-04-2006 18:00:37
They were the same engine, many ended up retrofitted to B & C tractors. They were governed a little faster.
