WD WD45
Hand Crank
10-03-2006 11:31:55
What is the best & easist way to tell a WD from a WD45? Thank`s in advance, Don.
John (MO)
10-03-2006 11:48:41
 Re: WD WD45 in reply to Hand Crank, 10-03-2006 11:31:55
All WD engine blocks have a removable side plate while no WD45 blocks have the plate. All WD45's had a curved shifter while only the last year or so of WD's had the curved shifter. Serial number is below the left brake cover stamped into the rear end of the tractor. Check serial number against list that can be found under a hot button on the lower left of this page. WD engine block could be easily converted to hold WD45 internal parts and by now a huge % of them have been so overhauled. Likewise, after all this time, lots of tractors no longer have original rearends, transmissions or motors, but are parts and pieces of various tractors.
