Hinge on tool box
Notminiacres
10-02-2006 01:40:43
Can some one tell me if the little wire like pin that goes through the hinge on the tool box, can it be removed to change tool box lids? A friend of mine says NO. I think it can, if it can be what is the procedure to remove it. Sure hate to have to take the whole assembly off, just to replace the lid to tool box. Thanks in advance.
Notminiacres
10-02-2006 01:42:29
 Re: Hinge on tool box in reply to Notminiacres, 10-02-2006 01:40:43
Forgot to tell y'all that this is a tool box lid on a Model "C". Thanks again
chalmersbob
10-02-2006 19:27:34
 Re: Hinge on tool box in reply to Notminiacres, 10-02-2006 01:42:29
the pin can be removed. i have done it. need a small drift punch to get it started, some oil, then work it loose and remove with a pliers. Bob
Notminiacres
10-02-2006 19:36:44
 Re: Hinge on tool box in reply to chalmersbob, 10-02-2006 19:27:34
Thank you Bob, I thought that might work. I knew it was going to be a lot of work to take the whole assembly off, was hoping this would work. Again, THANKS!
Notminiacres
10-02-2006 19:36:44
