Allis C wide front end
Jim Hunter
10-01-2006 12:20:44
Got a C with a wide front end. The pivot nub is sheared off the cross bar. Guess I will get something welded on in place of it. Any body got any better ideas. Thanks
Fall Farm
10-22-2006 03:16:09
 Re: Allis C wide front end in reply to Jim Hunter, 10-01-2006 12:20:44
My husband just bought an Allis-Chalmers C yesterday at an auction with a wide front end. I would like to find out more information on it. Is there a serial number on the tractor some where to look it up in a book. and to get equipment for it.
M Nut
10-22-2006 06:25:40
 Re: Allis C wide front end in reply to Fall Farm, 10-22-2006 03:16:09
Yes, look right in front of the gear shifter. The serial number should be casted right into the metal there.
85_Ranger4x4
10-02-2006 22:32:37
Yeah, the C front axle is more like a traditional axle, it comes straight out and down to the wheels at close to a 90 degree angle, and is adjustable width. They were not that common though, I had a chance to get one for mine a couple years ago.
Kip[UT]
10-02-2006 14:09:33
I assume you are talking about the pivot at the back of the wishbone that goes through the cast lug on bottom of the bellhousing. I'd just grind it flush where the stud is missing, then take the proper size Grade 5 bolt & drill it for a cotter pin, cut the bolt head off & weld it to the wishbone. Then secure it with a castle nut & cotter pin. I did this to replace a badly worn pivot pin & made mistake of using grade 8 bolt & after ruining several bits trying to drill the cotter pin hole, finally resorted to double nutting it as I had enough threads.
old
10-01-2006 18:18:45
Sounds like you may have a front end off a B and if so you should be able to get the part from AGCO
chalmersbob
10-02-2006 19:30:22
 Re: Allis C wide front end in reply to old, 10-01-2006 18:18:45
the c wide front end has a pivot pin in it also, so does the ca wide. Bob
old
10-02-2006 21:15:44
 Re: Allis C wide front end in reply to chalmersbob, 10-02-2006 19:30:22
So far I have never seen a C with a wide front end on it other then one taken off a B but you never know what you will see on one
Jim Hunter
10-04-2006 19:41:53
 Re: Allis C wide front end in reply to old, 10-02-2006 21:15:44
I think I will just get a bolt and have it welded on. Doesn"t seem like much pivoting gets done. It says the pivot pin is welded to the axle then goes into the axle support
