wd45 bellhousin'
slowride II
09-30-2006 19:33:22
will a wd 45 bellhousing fit on a wc?
i need a starter for my 34.
slowride>
JMS/MN
10-01-2006 06:25:46
 Re: wd45 bellhousin' in reply to slowride II, 09-30-2006 19:33:22
The front side will bolt to the engine. The back side will not bolt to the transmission. If you want a starter, you need the housing from a styled WC.
John (C-IL)
10-01-2006 07:25:51
 Re: wd45 bellhousin' in reply to JMS/MN, 10-01-2006 06:25:46
Agree that you need a bellhousing from a styled WC. Should be easy to find, I'm sure that Doc's Equipment in Lacon, IL would have them. There are many other Allis vendors that could supply them also.
Aaron SEIA
10-01-2006 05:18:23
I'm not sure since the trannys are different. A bellhousing from a 39 and newer WC would, of course. All the styled WC's had starters.
Aaron SEIA
old
09-30-2006 21:39:40
O would think so since you can drop a WD45 engine in to a WC or WD. so they should be the same. I know I had a WD45 engine in my WC speed patrol at one time
