WD or WD 45
SRA
09-29-2006 07:52:44
How do you tell the difference between WD and WD-45? I know the tractor is a 1949 it was my great grandfathers. I am going to try my hand a restoration of an orange one this winter. I have done red and Green. Thank you
old
09-29-2006 09:26:20
 Re: WD or WD 45 in reply to SRA, 09-29-2006 07:52:44
As Mike says. If its a 1949 then its a WD, WD45 didn't come out till around 1953 or so. But and this is the big thing. A WD45 engine will bolt right in to a WC, WD, or a WD45. A WD45 has a curved shifter, and the engine doesn't have a plate that bolts on to it on the right side. The WC/WD both have the same engine and theres a plate on the engine on the right hand side that bolts on. Sort of like last weekend there was a 1950 WD tractor at the show, it was marked as a 1950WD but its wasn't a true WD because some one had swapped the engine out and put a WD45 engine in it. But it also wasn't a WD45 it was just one some one had put togeather that way
MikeRW
09-29-2006 08:12:45
If you are certain its a 49 then its not a WD45. There is a stamped SN on the back of the tractor right behind the left brake cover. It on a vertical area and is hard to see. Need to get that number to get positive ID.
