Tip On Checking Plugs
Dick L
09-26-2006 12:11:40
You can lay a screw driver bit from the end of the plug to the block and the plug that gives you no change is the one not firing. Then you can pull the plug wire off the plug and hold it about 1/8" away from the end of the plug to watch the spark. If you have spark and a bad plug the miss will go away. Tuch the wire to the plug and the miss comes back and then pull it back and the miss goes away again, it is then a bad plug. Old timers test from way before my time and it was shown to me in the 1950"s.
