Snap coupler plow
WD_Fan07
09-24-2006 13:50:24
I just bought a 3-14 slat bottom snap coupler plow for my WD. Were there different models of these plows? I have seen 3 or 4 variations, this one has the big adjustment crank that goes all the way back to the 3rd bottom. Also, how does it hook up underneath? The drawbar and PTO shaft are on the tractor right now and someone said you need a special piece to hook up the long bar on the plow with the loop on it and take the PTO off. Also, one of the bottoms has a few broken slats, any place i might find a good one?
The Hook
10-09-2006 19:17:12
 Re: Snap coupler plow in reply to WD_Fan07, 09-24-2006 13:50:24
Just one more word on the PTO removal. The first coulter on that three bottom will come dangerously close to the splined end of the PTO shaft when the plow is raised and it swings back and forth on the linkage. Probably depends on exactly how deep you have the coulters set. I spent a couple hours on mine filing out the dings before I could use the PTO again.
wolfman
09-28-2006 19:16:31
If the adjusting crank mechanism goes back to 3rd bottom, sounds like a 70 series. 70 series had a lot more clearance than the 60 series - could handle heavy cover crops more easily without plugging.
WD_Fan07
09-27-2006 13:47:44
Thanks for that info, I think it is a 60 series. One more thing, what is the routing of the release chain for the snap coupler bell on a WD and where is the lever, if any, that it attaches to?
Tramway Guy
09-24-2006 17:01:18
There were at least three different models of plows that could be snap coupler...the '50','60' and '70' series. The '52' was two-bottom, the '53' was three-bottom, etc.
The '50' series first came out with the 'pin hitch' and the beams that held the bottoms were at 90 degree angles to the frame.
The '60' series had angled beams, and I think were only available in Snap Coupler style.
I am not sure of the '70' series, except that I think they were available in more than 3-bottom styles, perhaps with a gage wheel.
If you do not have the 'Snap Coupler' bell underneath the tractor, you can get one used somewhere. You would also need the latches for the lift arms. Or you could retrofit the plow with the 'pin hitch' style attachments.
With either style, you have to remove the drawbar (except the very early plows that ysed the drawbar to pull with). Shouldn't have to remove the PTO shaft.
