170 Traction Booster system is equiped with "feed-back" linkage. the feed-back linkage prevents the draft arms from raising too much or lowering too much when changes in draft arm load occur. There are 3 holes in the feed-back lever for adjusting the feed-back link(flat strap). the upper hole provides the minimum amount of fee-back and the greatest amount of lift arm travel when loads change. The bottom hole in the lever provides the maximum amount of feed-back and the least amount of lift arm travel when draft loads change. The center hole in the lever provides a medium setting. Experience has shown that under most conditions the maximum amount(bottom hole in lever) of feed-back is the best position. It may be desired to use the center or upper hole in the lever when working over terraces or other extremely uneven ground. Place the tractor lift arm lever in the traction booster position. Move the TRACTION BOOSTER lever all the way forward. Move the position control lever all the way rearward. set engine speed at 1000 rpm. Turn nut on position control rod until the ends of the lift arms raise to within 1" of the full-raise position. This is probably clear as mud. as there are 3 pages that address how to set it correctly. The torsion bar preload must be set first then traction booster linkage then feedback linkage then position control linkage.then check lever friction,rate of lower,high volume bleed off,large pump relief,traction booster system relief valve,pressure release. It may pay to order a manual. Sorry i can not give you a quick set up.
