WD throttle linkage Choke linkage
James Glendenin
09-23-2006 07:50:05
When I removed my Zenith carb for overhaul I noticed (if I remember correctly) 2 springs connected to the carb. When the carb was overhauled and ready for reinstall I couldn"t find but 1 spring and then didn"t remember how it was connected. My tractor seems to run fairly well at first but then seems to choke out. The choke rod has no spring attached currently to pull it back to it"s unchocked position and I was wondering if as you increase throttle shouldn"t the choke plate open up to allow more air into the carb? It currently doesn"t.
P.S. I"m a Sheetmetal mechanic not an auto mechanic :)
John (C-IL)
09-24-2006 06:59:19
 Re: WD throttle linkage Choke linkage in reply to James Glendening, 09-23-2006 07:50:05
I just had the same experience with the choke on a WD. Turns out that the chock was rotated 180 degrees and the lever on the choke rod was pointing up instead of down. Positioned the lever the correct way and everything works good.
Nebraska Cowman
09-24-2006 05:04:54
No, the choke is independant of the throttle. You work it manualy with the rod. Should be pull rod to choke, push in rod for normal run. I don't think they used a spring. If yours is backwards it may be your carburetor is for a different applicatinon and has the wrong choke shaft. No biggy. But if your choke is working back closed you might want to use a light spring. The throttle rod where it comes back from the governor should have a light spring to the block drain to prevent surging. No biggy on that one either. Many have run for years without it or hooked up wrong.
old
09-23-2006 21:11:37
You say pull it back to unchoke it, thats backwards. You pull it to choke and push it forward to unchoke it. Sounds like you have some thing hook up wrong
big jt
09-23-2006 08:13:02
James
The choke plate is just for starting. It should be open after the tractor is running or you will get the symptoms you describe. I don't have the parts book in front of me but typically you will see a spring from where the choke rod hooks up to the block drain. Sometimes the spring will be run through the rod inplace of the cotter pin.
Seems like I have also seen a LIGHT spring hooked to the throttle. I imagine this would be to reduce surging or to allow shut down when the engine eats a governor weight but don't know for sure.
JM2CW
jt
