One more time!
tnt
09-17-2006 09:53:48
third party image
Eldon (WA)
09-17-2006 10:21:49
 Re: One more time! in reply to tnt, 09-17-2006 09:53:48
Looks like a WD45 with factory power steering... a nice set-up. Those Farmhand loaders are heavier than they look, also the rear wheels are set quite wide to allow for the mounts. It probably won't fit between the fenders on a regular carhauler type trailer. I'd guess the rear wheels are filled with CaCl, whole thing probably weighs close to 6k. Where is it located? Those loaders were very common in the midwest and used to stack loose hay. They lift high enough to scare ya when you are sitting in the tractor seat!
old
09-17-2006 10:09:43
Looks to be a WD or WD45. You can tell the differance in the 2 by the shifter and if it has a bolt on plate on the left right side of the engine. By the way the weight of a WD or WD 45 is less then 5000LBS but not by much so with the loader it could be around 5500LBS give or take a little. I know I wouldn't be afraid to put it on the 16 foot trailor I use and haul it. I haul my Oliver Super 88 all the time and it weights in at just under 5500lbs. I also hauled a Case 800 in one time and its around 6500LBS on the same trailor but I also took it real slow and made sure I had a lot of room to be able to stop. So if it where me I would haul it and not be afaird doing so
gatz
09-17-2006 10:06:50
see if this works....
Third Party Image
TnT
09-17-2006 09:55:08
I'm getting closer! At least I got a box with an x in the middle. I think I;'ll quit while I'm behind.
Janicholson
09-17-2006 09:57:50
 Re: One more time! in reply to TnT, 09-17-2006 09:55:08
Don't quit, it works! see below and how to do it. JimN
