Condenser question
Hand Crank
09-15-2006 17:45:27
Will a bad condenser keep an engine from starting?
Just what is the function of a condenser?
Thank`s Don.
souNdguy
09-16-2006 22:31:30
 Re: Condenser question in reply to Hand Crank, 09-15-2006 17:45:27
Think of it as a switch debouncer.. ( among other things.. )
Soundguy
John T
09-17-2006 14:24:08
 Re: Condenser question in reply to souNdguy, 09-16-2006 22:31:30
Good analogy, how bout kinda like a "shock absorber" lol
John T
souNdguy
09-17-2006 17:21:06
 Re: Condenser question in reply to John T, 09-17-2006 14:24:08
While it literally 'absorbs' shock of the dc variety.. I think that would be more descriptive of it's basic operation.. i.e. charge collector, condensor.. etc. The 'switch debouncer' is more indicative of it's operation inside an ignition circuit, at least for primary purpose anyway, as in that circuit, it's wearing a few hats.
I like the 'shock absorber moniker.. .. it's a very literan description.
Soundguy
John T
09-16-2006 09:44:14
Hand Crank, As well stated by the other gents below with which I agree and to answer your question:
YES its possible (depending on how "bad") a bad or incorrect sized condensor might prevent starting ESPECIALLY on a Magneto Ignition. She can still spark WITH NO CONDENSOR but the sparks weaker and the points would burn up quickly. Just like any other short at the points, a shorted condensor causes NO SPARK. The correct value and working condensor maximizes spark gap energy by controlling the rate of collapse n discharge of the coils stored energy PLUS saves the points from premature burn up cuz it absorbs (its like a big open bank waiting to accept electrons) some of the energy and reduces the arcing n resultant burning across the points.
Its possible to do a very preliminary test of a condensor using only an analog ammeter to see if its shorted or theres not much capacitor action at all BUTTTTT T that can only tell you if its BAD BUT NOT if its good..... ....that takes a true condensor tester.
If in doubt for no more then they cost TRY A NEW PROPER SIZED ONE is my advice.
John T
Bob
09-16-2006 08:14:21
The condensor stores and releases energy, preventing "arcing" at the breaker points.
Without a condensor, the energy it stores and releases back into the coil is dissipated as HEAT from the arc across the breaker points, which WASTES energy that would otherwise contribute to a "HOTTER" spark.
Kent of SW MO
09-16-2006 06:45:40
The function of a condenser in an ignition circuit is to cause the magnetic field, that has built up in the coil when the points are closed, to collapse faster which yeilds a hotter spark. Open cap weak spark. Shorted cap no spark. when you have a weak spark always replace the cap first. It is the cheapest and normally the fasted repair to do. If this does not fix the problem them you look further.
Kent
old
09-15-2006 19:22:40
Easy way to explain a condenser is that its a very fast charge and fast discharge battery. Thats not 100% correct but gives you an idae of what it does. Also most of the time when one goes bad the points will also go bad at the same time because they get burned badly. A condenser sort of controls have much the points have to do and helps keep the points from takeing all the volts/amps. So when a condenser goes bad the points burn out fast because they are takeing all the volts/amps instead of being buffered by the condenser
JMS/MN
09-15-2006 18:47:17
Function of a condensor is to 'condense' or 'store' electrical charge- then release it at the proper time. Sort of like a 'big bang' when necesary. Charge builds up in storage and then is released to fire the plug.
Gerald J.
09-15-2006 18:23:27
If the condenser goes open, the spark will be wimpy and yellow.
If the condenser shorts, there will be no spark at all.
In between a poor condenser can lead to poor spark.
The condenser protects the points and makes the coil ring to get a fat blue spark that is better at igniting the fuel than a thin yellow spark.
If the condenser value is off, it will lead to material transferring from one point surface to the other. Either case makes the points last less well. No condenser or open condenser erodes the points most rapidly.
Gerald J.
Hand Crank
09-15-2006 18:23:21
Thank`s for responding Dick!
The tractor is a 1949 WD.It has a Dist.
Dick L
09-15-2006 17:54:30
It can. Does the tractor have a magneto or distributor?
