WD starting problem after sitting
Will Herring
09-15-2006 12:01:35
I"ve noticed that if I let my WD sit for about 2 weeks, when I go to start it... It doesn"t really want to start. But if I give it a little extra choke and try it, it"ll blow a little bit of fire and putter right up after a minute or so. It"s handy to have the 12 volt battery, but any idea what is causing it to be such a hard start? Not enough gas initally? Dampness inside the manifold/exhaust system?
old
09-15-2006 12:05:41
 Re: WD starting problem after sitting in reply to Will Herring, 09-15-2006 12:01:35
Whats the spark like?? Weak spark,corredded points will cause that problem. Or of course a float that sticks some will also cause that problem and chokeing it sort of causes it to get more gas.
Will Herring
09-15-2006 13:16:52
 Re: WD starting problem after sitting in reply to old, 09-15-2006 12:05:41
It's got good spark from what I can tell... And the carb has been worked on so that it's in decent shape... I've not had any "sticking" problems, really.
old
09-15-2006 13:43:54
 Re: WD starting problem after sitting in reply to Will Herring, 09-15-2006 13:16:52
Do you turn the gas off when you park it or leave it turned on?? If you turn it off which is a good idea then the float can stick till the gas has a moment of 2 to free up the gum that does form on the needle. As far as good spark you need to check that by turning the engine over and holding a plug wire or a plug to the block to make sure you have a nice blue spark.
Will Herring
09-15-2006 14:02:29
 Re: WD starting problem after sitting in reply to old, 09-15-2006 13:43:54
Yes, I always shut the gas off when I turn the tractor off. Common practice for me.
old
09-15-2006 14:51:19
 Re: WD starting problem after sitting in reply to Will Herring, 09-15-2006 14:02:29
Probably the needle sticking in the seat just a little then. I've had that type of problem with more then one tractor, but if I turn on the gas and wait 5 minutes or so they start right up. But if I just try right off the bat they don't want to start fast. One thing that can help that is if you turn off the gas and let the tractor then run out of gas, then shut it off. That makes sure the float/needle is in the down position
Will Herring
09-17-2006 02:56:35
 Re: WD starting problem after sitting in reply to old, 09-15-2006 14:51:19
Thanks, I will try both of those things!
