WD45 Starter Grinding Noise
MikeRW
09-15-2006 05:48:15
When engaging the starter on my WD45 about 50% of the time the starter doesn't engage into the ring gear and then there is a grinding noise until the starter stops rotating. When this happens and i attempt to start it will usually engage into the ring gear and start right away. Is this a starter issue, ring gear issue, a combination of both. Is the grinding noise the gear on the starter grinding on the ring gear. This can't be good.
Texas Denny
09-15-2006 07:33:25
 Re: WD45 Starter Grinding Noise in reply to MikeRW, 09-15-2006 05:48:15
Mike, the issue is the starter drive on the end of the shaft of the starter motor. These occasionally get dirty and won't spin out like they should. I've pulled these out and thoroughly cleaned the drive mechanism. Before reinstalling, I've put a little light oil on the spin out thread. Heavy oil will cause it to stick. Usually, if nothing is broken, it will work fine after reinstallation. You can clean the drive pretty well without taking it apart. Simply use a good solvent and rotate the drive first one way and then the other. Let it dry completely. Then the light lubricant and reinstall.
MikeRW
09-15-2006 07:54:00
 Re: WD45 Starter Grinding Noise in reply to Texas Denny, 09-15-2006 07:33:25
Thanks for the info. Sounds like an easy fix.
