wc belt pulley
kevinjg
09-15-2006 03:55:51
i installed it last night and the seal was fine thanks for the responses,it tried different holes for backlash and it didnt sound right,i cant find an arrow like the manual says to line up and i took it out to look i saw a broken tooth on the gear inside,i cleaned it out to see if it was an old issue,seemed to be.questions how much back and forth rotation is o.k.? should i not try to run this with the gear like it is?it had alot of gear noise. any suggestions?thanks
K. Farmer
09-16-2006 19:49:13
 Re: wc belt pulley in reply to kevinjg, 09-15-2006 03:55:51
my belt pully makes a real bad noise but the teeth are good on both gears. are there any bearings that could go out? and if there are how can i buy and replace them? Thanks
JMS/MN
09-15-2006 08:34:07
There is no standard position for the arrow- pulley should be fitted to the individual tractor. Try different holes for the setscrew until you find one where you can rotate the pulley 1/8 to 1/4 inch. Mark that spot, top of the sleeve, with a punch.
Texas Denny
09-15-2006 07:39:43
If you use it with a broken tooth, you may take out all the teeth on both gears. Are you needing to do belt work? If you aren't doing belt work, put the pulley in the out position and leave it there and don't bother to fix the gear. It is very hard to shift the tractor with the pulley engaged so it isn't engaged unless it is being used. As far as I know, the only time the tractor is driven with the pulley engaged is with a mounted corn picker which uses the pulley to drive the husk blower.
If you are doing belt work, the inside gear must be changed.
kevinjg
09-15-2006 09:11:23
 Re: wc belt pulley in reply to Texas Denny, 09-15-2006 07:39:43
thank you for the quick responses,and also the answer i thought of its just nice to have a second opinoin.i was going to use this for enjoyment this fall running some old machines,so i can either fix the gear or use this as an excuse to buy more tractors.thanks.
