Do Allis B's run cold ?
MMB
09-14-2006 17:09:10
I have a new Allis B here, 1946 model. It runs decent but I can't seem to coax any heat out of the engine. It runs at about 130 degrees only and should be probably 40-50 degrees hotter I would think. It has the thermostat housing on the engine but whether there is one in there or not I don't know. It's either missing or maybe stuck open. And the temperature gauge I think is in a strange place, on the radiator side of the thermostat (or thermostat housing) for some reason, is that normal? Someone has removed the factory shutters. A guy I know has two of them and he says they are the darndest engines to get warm. Any comments from any of you that have experience with the Allis B's?
K. Farmer
09-16-2006 19:54:34
 Re: Do Allis B's run cold ? in reply to MMB, 09-14-2006 17:09:10
I have the same problem with my WC, it stays under 125 all the time, I grind feed with a big hammermill, that should be run with a 100 hp tractor but the WC runs it fine and it warms up to 135 and thats it. It confuses me.
ohio
09-16-2006 19:44:30
MY 39 RUNS @ ABOUT 140-170, DEPENDING UPON LOAD.
jeffalex2
09-14-2006 18:44:26
Yep, be very careful if you change it. I did mine while doing a head gasket and had to drill out and re-tap all the holes. Nice now that it's done, but, a big pain to do. If you order a thermostat in advance, get the spring too. My thermostat was OK, but, the spring that holds it in place had broke letting water flow all the time.
old
09-14-2006 18:13:59
I have the opposit problem with my C. Same engine as your B. Be careful if you try to put in a new thermostat. The bolts like to brake off right at the head and can be very hard to get out if they do. My C has the shutters but I always leave them wide open because it likes to run a little on the warm side
ramblineagle
09-14-2006 17:11:56
my 1950 B runs about 170 degrees all the time. you need to install a new thermostat.
