1953 Allis Chalmers WD Starting Problems
laMartin
09-13-2006 18:48:53
After running my 1953 AC WD (gas engine) tractor for an extended period at high throttle, I stalled going up a hill and the ground strap to the battery was smoking when I shut the tractor down. I have not been able to restart the tractor and believe I must have fried some electrical component. I am looking for suggestions about what electrical components I should begin replacing first. Also, is there a regulator on the charging system that is malfunctioning to overcharge the battery?
BCnT
09-14-2006 15:00:00
 Re: 1953 Allis Chalmers WD Starting Problems in reply to laMartin, 09-13-2006 18:48:53
ok...does the tractor spin over now or is everything completely dead? first thing i'd do is disconnect battery and see if it'll take a charge...then check the big battery wires for bare spots or anything touching frame of tractor...same with smaller wires.
also was the cable smoking after you tried to restart tractor or smoking right after tractor died?
