B Allis wiring
Nat
09-13-2006 17:47:16
I just got an old B allis.It runs, drive works looks good, small dent in hood , nice grill nice fenders fair tires. My problem is the wiring. It is 12 V Positive ground with a generator. The wiring is cobbled together, wire nuts and splices everywhere. I want it to be neg ground and I"m not sure exactly where to start. Is the battery charged backwards? If I remove the wires from the generator and switch the battery around will I burn it up? I need some ideas. Thanks in advance, Nat
Mike (MA)
09-14-2006 15:46:22
 Re: B Allis wiring in reply to Nat, 09-13-2006 17:47:16
Nat -
If you wanted to remove all the cobbled up wires and start over, Duey S"s page does nice a job of laying out the various wiring configurations for the early ACs. The link is listed below.
Mike
steve(ill)
09-13-2006 18:33:45
if you send me a e-mail, i will send you a 12 volt generator print. [email protected] ----- - basically- the tractor was 6 volt positive ground when new. someone could have put a 12 volt battery and a regulator and left the 6 volt generator in place. that kind of works if you have a good generator. if you want to be negative ground, that is easy to do. basically the regulator must be able to be used on a negative ground system, some are not. the generator has "F" and "A" terminals. these go to the regulator "F" and "G" terminals. The "B" on the regulator goes to the ampmeter, other side of amp goes to + on the battery, and the negative side of battery is grounded. if you have a magnito ignition you are ready to go. if you have a coil (not standard) the coil should be 12 volt . not negative + side of coil goes toward the key or kill switch.--- run a big wire from the + terminal of battery to the starter switch terminal. i changed mine to starter button and use a solenoid off a old Ford truck, you may keep the poke rod starter.
Nat
09-14-2006 12:46:40
 Re: B Allis wiring in reply to steve(ill), 09-13-2006 18:33:45
E-mail on the way. I appreciate the help, and may have other questions. Later, Nat
steve(ill)
09-14-2006 18:50:02
 Re: B Allis wiring in reply to Nat, 09-14-2006 12:46:40
sent photo and got it back that your are blocking incoming mail.
Nat
09-15-2006 13:23:39
 Re: B Allis wiring in reply to steve(ill), 09-14-2006 18:50:02
Steve I got it, don"t know why it came back, it showed up here and I have already begun working on it, Thanks. Will shoot you an e-mail and see if I can tell what went on. Later, Nat
