B brake spring holes
D13
09-13-2006 08:25:31
Ended up with a set of manual brake final drive housings on my foot brake B. If I remember correctly the hole in the housing that the spring hooks to is higher for the foot type. Or is it the screw adjuster (which I have) versus the nut adjuster? Either way, can someone tell me how far down from the seat rail mounting flat the top of the hole should be for a foot brake screw adjustor set up?
Thanks in advance
Dick L
09-13-2006 11:01:28
 Re: B brake spring holes in reply to D13, 09-13-2006 08:25:31
I never put a rule to them but have changed several B"s over to the foot brakes using the orginal final drives and the same springs work for both.
Rod (NH)
09-13-2006 10:11:41
Hi,
That hole on my '42B with foot brakes (w/screw adjuster) is vertically oblong in shape, about 1/2" wide X about 3/4" long (tall). The top of the hole opening where the spring hook attaches is about 2" down from the flat where the fender/seat support angle mounts.
third party image Rod
