WD starting problem
Hand Crank
09-12-2006 14:38:02
Hi fellers!
Still can`t get my WD to start.It started & ran fine this spring.New cables,battery is fully charged,coil is good.Starter engages,but won`t quite turn the engine over.Could it be the starter or the condenser?What would happen if I tried to start it with a 12 volt battery?
Any help appreciated,Don.
Roger Nolin
09-12-2006 20:46:27
 Re: WD starting problem in reply to Hand Crank, 09-12-2006 14:38:02
What size cables did you get?? if they are the small diameter like 12 volt uses, they will not work. Need to be the big diameter cables. Roger
John T
09-12-2006 17:18:38
You say the cables are new, but just to be safe I would remove, clean n wire brush then reattach each n every battery n starter n ground cable and make sure the ground cable is to a clean tight main frame type bolt. You may wanna have the battery load tested just to be safe. Then if shes still a slow cranker, I agree with Old it may well be the starter is simply bad. If thats the case 12 volt may make her crank fast for a while but the starter is probably gonna need attention. It may just need new brushes or bushings and hopefully the armature is still okay.
John T
old
09-12-2006 14:51:12
The condenser has nothing to do with the engine not turning over. I would pull the starter off and have it checked. Starters do get weak and when they do they will not turn the engine over. Yes you could try a 12 volt battery but if you ran it long that way you might burn up the coil and or the points
