Hi, The B transmission, differential and PTO share a common sump. The capacity is 6 qts for the transmission and differential. That becomes 7 qts if a PTO assembly is in place. The early manuals for Bs without hydraulics called for SAE 140 (above freezing) and SAE 90 (below freezing) for the transmission/differential/PTO sump and also for the final drives (1.5 pts each). When hydraulics were added to the later PTO housings, the heavy oil was too heavy for that service and the requirement changed to SAE 20 oil, period. The 20 oil is indicated in later manuals, even for the final drives. My 1942 B never had hydraulics and I always ran SAE80W90 in all the above areas until I added the standard hydraulic pump to my PTO assembly. When I did that I changed the transmission/differential/PTO lubricant, which also serves as the hydraulic fluid for the pump, to a modern combination transmission/hydraulic fluid, SAE10W20. I continue to use 80W90 in the finals despite the newer manuals reference to SAE20 because I prefer the heavier oil there. I use the 80W90 in the finals because the weather in my state gets well below freezing in the winter. I don't change the lubricant in the finals because of temperature. If I were consistently above freezing year round, I'd use the SAE140 there. Rod
