Allis Chalmers WD45 Valve Seats-boots
Scott Pumphrey
09-12-2006 11:23:03
I am new to the Allis Chalmers brand, but inherited 2 when I bought my land. I have a kit for my 56' gas engine and was putting in the valves when I noticed that I don't have one of the rubber boots that goes under the springs. Any idea what these are for? I looked at an older WD tractor head that I removed and it doesn't have these.
Thanks to all for the great advice I see here!!!
BCnT
09-14-2006 15:05:54
 Re: Allis Chalmers WD45 Valve Seats-boots in reply to Scott Pumphrey, 09-12-2006 11:23:03
chances are the engine had worn guides and previous rebuilder put valve stem seals in rather than renew guides.
Butch(OH)
09-12-2006 11:49:36
As Dick said those "boots" are valve stem seals. Early on in the "W" engine production there was some oiling problems. They were all adressed long before that engine became the W-226 in the WD-45 with changes in the rocker design and oil sheds. Assuming it does not have a 1935 head and rockers and you have corrected valve stem to guide clearances during your rebuild you need not worry about seals, they are not needed nor are they desirable.
Scott Pumphrey
09-18-2006 05:12:54
 Re: Allis Chalmers WD45 Valve Seats-boots in reply to Butch(OH), 09-12-2006 11:49:36
There must be another method that I haven't seen that keeps the oil from entering the cylinder... Or would this be minimal?
Thanks all for your help!
Dick L
09-12-2006 11:38:15
The valve guides were designed to be lubed from the top. By using the valve guide seals you reduce the lube systems ability to properly oil the valve stems and will get premature valve guide wear. If it is not being used by its self to farm 200 acres having the seals on will probly never cause a problem. All I was saying is they are not needed!
