Hey Rod
Dick L
09-10-2006 18:00:58
I have most of one of those manual lifts you are talking about (I think). It was in a pile of B stuff that I bought. It didnt seem to go with anything I have but I knew it was a manual lift of some sort to fit a B. It is rusted bad and nothing moves but it has two springs on it that I would guess still would be good. I just moved it yesterday to get it away from space I needed. On the other hand it could be something completely different.
Rod (NH)
09-11-2006 05:23:53
 Re: Hey Rod in reply to Dick L, 09-10-2006 18:00:58
Dick,
There were manual lifts for the standard AC pick-up plows also:
third party image
They are quite different from the manual lifts for the aftermarket WIARDS:
third party image
I don't think the manual lift versions of B plows are that common, even the AC ones. Anyone trying to piece together workable pick-up plows for use on a B w/o hydraulics would be interested in what you might have, I would guess. I'd try and find out exactly what you've got there. It could be worth more than you think.
I am told that there were "several" manufacturers of plows for the B, especially during the war years, but I don't know how true that is. I am only aware of the standard AC ones and the obviously different WIARD ones that I have. Luckily I remembered how to install them from years ago, otherwise I would be scratching my head. I don't know if DAD ever had a manual for them. It wasn't with the other manuals that he kept so there may not have been one. I have never seen a reference to one either.
Rod
Dick L
09-11-2006 06:55:04
 Whatever I Have in reply to Rod (NH), 09-11-2006 05:23:53
I see that it is not all there. The only thing that looks like your drawing is the numper 11. The lifting lever does not have notches. I will take a picture and maybe someone can figure it out.
Chris (OR)
09-11-2006 10:06:25
 Re: Whatever I Have in reply to Dick L, 09-11-2006 06:55:04
I have also been looking around for the piece to complete a manual lift plow for a b. I have the plow, disk, main beam, front u-bar (round bar that goes between the final drives, u-bar brackets and one of the control levers (the smaller one that I think set the angle). But I still need the other lever, and the lift assy....
Does anyone have an original AC one of these?
Dick L
09-11-2006 10:16:48
 Re: Whatever I Have in reply to Chris (OR), 09-11-2006 10:06:25
I had three of the front drawbar lift levers. I gave the one away that was good. I just repaired one for my use and am not sure if the other one is repairable. They were all on B"s that I bought.
