V8 in a WD
Rob03
09-10-2006 12:23:04
Wanting to install a V8 in a WD. But was wondering what kind of a flywheel I would need to run. The tractor will not be used for any work or pulling. It will be for show only. The engine will be a 350. Any help would be appreciated. Rob
BCnT
09-11-2006 07:49:56
 Re: V8 in a WD in reply to Rob03, 09-10-2006 12:23:04
tractor flywheels are very heavy to create torque...if by ''show'' you dont mean pulling then the stock chevy flywheel will work IF it'll fit inside the WD's bell housing.
then all ya really gotta worry about is matching up bolt pattern between back of block and bell housing...the rest is fairly easy.
Lance L
11-04-2006 17:40:26
 Re: V8 in a WD in reply to BCnT, 09-11-2006 07:49:56
Years ago,I put a Ford 292 in a WC. Used the ford clutch and 3 speed trans with a shortened shaft and hooked it to the 4 speed trans of the tractor. It had 12 forward gears and I pulled it in tractor pulls. This would work good for what you want. Only one problem, it will run about 60 MPH. Hang on.
