190xt hydraulic lift hesitates
hig
09-09-2006 16:29:00
the lift arms as well as the remote cyls. do same thing. might take several seconds before they work. hot,cold makes no difference. steering isnt 100% but is no problem when moving.hi,lo rpms makes no difference either. any body seen this before?
Floyd352
09-13-2006 16:15:05
 Re: 190xt hydraulic lift hesitates in reply to hig, 09-09-2006 16:29:00
I think there are 2 possibilities first a slightly plugged oil cooler or a pinched feed line from the res to the pump, The other is in your filter. The heating is normal but the oil cooler radiator if it is plugged will give you trouble. Leave a note and let me know how you make out
