PTO Cover on Unstyled WC
Garry from SD
09-09-2006 13:05:34
My dad just got the PTO put on the WC he bought this spring. We need to know, does the cover get bolted to the top of the plate the bearing mount is bolted to or between the mount and plate.
gene (missouri)
09-11-2006 08:52:03
 Re: PTO Cover on Unstyled WC in reply to Garry from SD, 09-09-2006 13:05:34
There are two rails mounted to the bottom of the bellhousing extending to the rear of the bellhousing/tractor.
The PTO shield - step plate is mounted on top of the rails. The PTO shaft carrier bearing is mounted below the PTO shield and bolted to the PTO shield.
Garry from SD
09-12-2006 08:15:20
 Re: PTO Cover on Unstyled WC in reply to gene (missouri), 09-11-2006 08:52:03
Thanks Gene for your help with both questions. Now I can tell my dad "I told you so!"
Have a good day.
