WD-45 Hydraulics Stuck Up!!!!!!
Paul Durbin
09-08-2006 20:08:01
Help! Someone tell me why my Hydraulics are stuck in the up position. They will not budge! Have been stuck up for 3 weeks and won't even bleed off.
jpscny
09-15-2006 07:09:45
 Re: WD-45 Hydraulics Stuck Up!!!!!! in reply to Paul Durbin, 09-08-2006 20:08:01
mine did the same to fix it I replaced 2 o-rings in the hydraulic hold valve which is bolted to the pump.
the broken o-rings allowed oil to bypass pressurizing system.
fynney1
09-14-2006 19:06:27
I screwed my front thumb-screw (see the discussion forum) all the way in - the loader stays up! I can't believe that all my connections and valves are so good that it wouldn't start coming down at least a LITTLE. ????? Is there a good place from which to drain the system? I'm not interested in making a big mess! :-)
Any guidance is appreciated!
Obsession
09-10-2006 16:09:15
Define bleed off. My WD's are stuck up too. It acts like the lever is still in the up position even if the lever is in the down position. Our WD45 did this once too. I believe a pin fell out inside the pump if I remember right. Not too hard to fix. You can sneak the pump out without pulling the frame rail off if you use some small screwdrivers to hold the rollers in while you sneak it through the gap in the frame.
fynney1
09-10-2006 18:34:09
 Re: WD-45 Hydraulics Stuck Up!!!!!! in reply to Obsession, 09-10-2006 16:09:15
Mine is doing this too! Can you give any more detail regarding dropping the pump and trouble-shooting? I am assuming that I need to remove all pressure off the system before I open the pump - should I drain hydrolics first? The front thumb-screw is all the way against the housing in front of it. Will this pose a problem in dropping the pump, or will it go straight down once the bolts are out and the linkage and fittings are disconnected?
I have not worked on one of these in almost 35 years, so it is good to get info from someone who knows what is going on! THANK YOU !
Obsession
09-24-2006 17:35:16
 Re: WD-45 Hydraulics Stuck Up!!!!!! in reply to fynney1, 09-10-2006 18:34:09
Turn in the thumb screw like the other John said. I tried it on mine and it worked!! I heard a click when I screwed the thumb screw in about the rounds. I had it adjusted out for plowing. You may want to relieve the presure first. BE CAREFUL!
John Rogers
09-10-2006 17:25:31
There is a thumb screw on the front end of the pump about half way down between the clutch housing & the pump. If you screw it in it moves the valve rack and always have caused the implement to drop for me . Good luck, John in NW MO
fynney1
09-14-2006 18:57:46
 Re: WD-45 Hydraulics Stuck Up!!!!!! in reply to John Rogers, 09-10-2006 17:25:31
I screwed mine (see the discussion forum) all the way in - the loader stays up! I can't believe that all my connections and valves are so good that it wouldn't start coming down at least a LITTLE. ????? Is there a good place from which to drain the system? I'm not interested in making a big mess! :-)
loa
09-09-2006 15:26:34
The return spring in the valve may be weak or rusty valve. If it has one
Craig in MO
09-09-2006 07:45:24
The '53 WD I bought this yesr had the same issue. I drained the pump, started the tractor and then they went down. Stopped the enginge, refilled and it's been fine ever since. No idea whay that worked for me but it did. Good Luck
Reaver
09-09-2006 06:23:17
Sounds like the same problem we have on our wd45 - we quite using it and have not had time to look at it...hydraulic pump always pumping arms up...put hydraulic lever up and down and it does nothing...input on how to fix this appreciated!
Reaver
Tramway Guy
09-09-2006 05:40:22
More information? Are you talking just the lift arms themselves? Without any weight to force them down, they will stay up forever.
