WC Throttle Response
rex37wc
09-08-2006 18:36:58
When advancing the throttle lever on my '37 WC, the rpms don't increase until the lever goes past 4 or 5 notches. Is this typical for this type of governor? The governor works well as the tractor is loaded and unloaded.
Gatz
09-08-2006 19:18:49
 Re: WC Throttle Response in reply to rex37wc, 09-08-2006 18:36:58
Linkage from throttle adjusted correctly?
Also, a worn throttle shaft hole can cause that.
See if you can wiggle it alot by hand.
