WD45 Snap Coupler
Toby Wellborn
09-07-2006 14:08:09
Does anyone know the proper setting or how the linkage should be set from the snap coupler to the release lever beside the gear selector. I replace the chain with from AGCO. It is just like the original. The only problem is that I just can"t seen to get might set right. When I pull a trailer the release lever going up and down when I pull a trailer and if I tighten up the chain the drawbar comes loose from the snap coupler... I know that the snap coupler does hang down somewhat...
Maybe someone has had the same problem...
John (MO)
09-07-2006 14:30:17
 Re: WD45 Snap Coupler in reply to Toby Wellborn, 09-07-2006 14:08:09
My suggestion would be to move the bell around and find the point at which it causes the release lever to raise to it's highest point. When the bell is in this position there should be no tension at all on the chain other than just the weight of the lever. If the lever has maxed out it's upward travel and there is more tension on the chain than just that of the lever, the coupler is going to start opening ever so slightly, or maybe even more than ever so slightly. If that is the case you need to let the chain out another link until all that tension is gone. Most every tractor I've been on will have that lever bouncing if the conditions are rough enough. It can also be that the latch in your bell is worn and needs some resurfacing. They can open up on their own even with no chain and lever attached if they are warn too much.
Toby Wellborn
09-07-2006 15:36:34
 Re: WD45 Snap Coupler in reply to John (MO), 09-07-2006 14:30:17
Thanks! John
I had the snap coupler off and it appears to be in good condition.
I'm going to try raising the bell and adjusting the chain to a position where the lever is better than half the distance from its lowerest point. Doing all this and not allowing the snap coupler to open.
wolfman
09-07-2006 17:54:37
 Re: WD45 Snap Coupler in reply to Toby Wellborn, 09-07-2006 15:36:34
Once you get the chain adjusted to your liking, try this: When you snap in the drawbar and hang it on the bail, give a good hard pull back as you tighten the clamp. Maybe a very hard pull.
