allis identification
otto l torgerso
09-07-2006 12:11:04
I just brought home an allis chalmers which i believe is a wc model from the mid 1930's. where do i find the serial number? also there is a hole on top of the govenor housing which i believe is where the oil is poured in but it does not appear to be threaded so what did they use as an oil filler cap?
Bill(Wis)
09-07-2006 18:16:50
 Re: allis identification in reply to otto l torgerson, 09-07-2006 12:11:04
If it's a WC from the 30's , look for the serial number on a flat spot on the back of the differential housing (pumpkin). In fact, it starts with WC-----.
Sid
09-07-2006 16:37:49
The oil filler cap is like the oil filler caps on the old six cylinder car engines it just slips on and off. Some folks call it a breather cap. You should be able to get one from agco.
old
09-07-2006 12:35:29
Numbers should be on the left rear axle houseing. Theres a flat spot where its stamped on. The oil fill cap as you have already found just slips on. Theres also another one under the hood on the valve cover but you can't use it with out pulling off the hood
