A C WD Fan belt change
The High Priest
09-07-2006 07:19:24
Fan belt is ready to break and while the changeout looks fairly straight forward, having never done it, I'm wondering how to proceed. It appears that I could remove the lower radiator hose to slip the belt into place, but any procedural advice will be appreciated.
Thanks in advance.
Hugh
The High Priest
09-12-2006 17:31:38
 Re: A C WD Fan belt change in reply to The High Priest, 09-07-2006 07:19:24
The fan belt change out was indeed straight forward!! The removal of the lower radiator hose gave me the necessary access. At 72, this old farm boy finally bought his first tractor on July 29th. (Obviously I did not choose farming as a way of life). I'm indebted to those of you responded. Thanks.
Hugh
old
09-07-2006 08:58:19
I would have to go look at my WD to be sure but it sounds like you have it right. One thing that helps is a pair of vice grips on the hand crank shaft to hold it out of the way when doing that belt change
CAL (KS)
09-07-2006 10:23:55
 Re: A C WD Fan belt change in reply to old, 09-07-2006 08:58:19
last time i changed a belt i had to loosen the radiator because the cast elbow at the bottom was too close to the crank pully to slip the belt through.
otherwise pretty straight foreward
