hydraulics for wc
Leon Dillard
09-07-2006 05:51:02
I have just purchased a nice an AC tractor. It was sold as a 1947 WC 45. It has no hydraulics. Can I retrofit hydraulics?
Craig in MO
09-08-2006 17:39:45
 Re: hydraulics for wc in reply to Leon Dillard, 09-07-2006 05:51:02
third party image
Try one of these PTO pumps. I have heard that they were used on the WC. I might be talked out of this one for the right $
Kent of SW MO
09-08-2006 06:43:00
It could be a WC-45 if someone put a WD45 engine in a WC but not likely.
Kent
steve(ill)
09-07-2006 18:54:19
no hydraulics on a WC. you might get a small pump or auto steering pump and mount on the frame at side of motor and run a belt off the front pulley. need a tank and hydrualic valve also. Old WC was a drawbar/pto tractor only. Newer WD had hydraulics.
old
09-07-2006 08:53:59
Never was a WC-45 made, just a plain old WC. So far I have never seen hyds on a WC, but they can be added with say a belt drive pump, PTO pump or one run off the front of the crank. There may have been a unit that will fit on a WC but I don't know of it if there is one
