Removing starter on WD
Hand Crank
09-06-2006 13:05:08
What is the method for removing the starter on a WD?I see a set screw with a lock nut on the starter housing.Could this hold the starter in place? Thank`s in advance, Don.
Justin Squire
09-06-2006 18:38:18
 Re: Removing starter on WD in reply to Hand Crank, 09-06-2006 13:05:08
If you are removing the starter because it isn't turning fast enough, read my post to your other question below this one. I had the same problem, but charged the battery for about two days with a charger and it turned quickly and started. You might try this if you haven't already. I guess it wouldn't hurt to have the starter serviced.
old
09-06-2006 14:26:40
Loosen the big nut, then remove the other bolt. Then grab the starter and pull/turn it and it will slide right out unless its rusted in BTDT and if rusted in you may need to tap on it with a hammer a little, just be sure to not hit it to hard and back and foruth side to side ir it will jam on you
Tramway Guy
09-06-2006 13:46:02
Sorry, should expand a little. The setscrew has a pointed end that fits in a hole in the starter nose. Loosen the locknut and turn the screw out enough to remove the starter. Only thing that might keep it from coming out is rust or a damaged nose cone (not likely).
Tramway guy
09-06-2006 13:42:32
Yup...
