Allis Chalmers 615
Brent Garber
09-05-2006 15:55:52
My 615 has a front end loader and a back hoe. After last winter, the front end loader is slow and jerky. The hoe is slow and low on power. I don't have any manuals other than the tractor's. Anyone know where I could get a tip or manual for these 2 accessories?
Thanks!
jgr(md)
09-11-2006 15:08:56
 Re: Allis Chalmers 615 in reply to Brent Garber, 09-05-2006 15:55:52
I think Kent is more on target. Sounds like water contamination in your fluid which will cause jerkiness. Could also be the pump itself. Just changing fluid and filters does not undo prior damage. Iron doesn't heal when injured.
jgr(MD)
09-12-2006 16:35:08
 Re: Allis Chalmers 615 in reply to jgr(md), 09-11-2006 15:08:56
check the pressure relief valve, look for leaks, check that the fluid you are replacing is the proper grade and GOOD quality. Don't go cheap on fluid. It does matter. check to make certain there isn't something loose floating around that could intermittently cause a flow blockage(ie.plastic wrap, paper, rust flake...etc.) good luck.
Brent Garber
09-11-2006 16:25:07
So after I check the pressure coming out of the pump and if it is good, what should I do next???
Thanks Guys!
Kent of SW MO
09-06-2006 06:56:16
Check you hydrulic pressure. Sounds like this is you problem. You said it happened after last winter. Did you maybe have some water in you hydrulic oil that could have seperated out, freezing up, and damaging the pump or other parts of the system.
Kent
Brent Garber
09-07-2006 03:42:33
 Re: Allis Chalmers 615 in reply to Kent of SW MO, 09-06-2006 06:56:16
Hi Kent,
I didn't do anything different last winter than any other. Filters are changed often. I changed the fluid with no change. No leaks
When using the loader, it will lift and then pause for 5 to 10 seconds, then lift a few inches higher. It doesn't make TOO much difference if it is loaded or empty. Someone said there is an unloader valve that may have junk in it but I'm not sure where it is located. Any clues?
Thanks!
